MattHopkins
Jan 04, 2017Guide
New firmware so much better (1.4.0.34)
Just wanted to let you guys / others know that the latest firmware (34) has solved so many of my problems. I no longer seem to get connection drops on my Apple products (my MacBook Air would lose the...
Michael74
Jan 15, 2017Guide
Hi,
just recognized that the procedure you described is mentioned by Netgear as well. Why they incorporated an update all button
is then a secret which only Netgear knows...*facepalm*
I updated till 0.34 always both at the same time since I was not aware of another
recommendation.
What if users HAVE updated both at the same time?
Do we need to reset the system or anything else to do?
An answer from Netgear support / mods would be very helpful.
BR
Michael
AndUrbi
Jan 15, 2017Guide
Michael74 wrote:What if users HAVE updated both at the same time?
I expect the recommendation for one-at-a-time is so that if something goes wrong with a satellite, your primary router is still working and you can debug a single problem at a time.
