Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
kyleb88
Oct 21, 2019Guide
Loaded up this firmware and factory reset. With in 10 minutes of it loading it had rebooted already and lost connection. I'll keep factory resetting and trying. Everything on auto and the satallite is just through the wall about 5ft away.
RBS should be father then 5ft. 30 is recommended to start.
Is this just test location distance or is this normal placement distance?
What is the Mfr and model # of the ISP modem the RBR is connected too?
kyleb88 wrote:Loaded up this firmware and factory reset. With in 10 minutes of it loading it had rebooted already and lost connection. I'll keep factory resetting and trying. Everything on auto and the satallite is just through the wall about 5ft away.
