Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
goldbondx
Oct 21, 2019Apprentice
3 outage since applying this upgrade in less than 3 hours. I will be verify ing if any ISP issues. But, overall not very happy at the moment.
CrimpOn
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
In addition to the Entrust Certificate for https, it would be helpful if someone verifies whether this change in OpenVPN means that new Windows/Mac/Phone ovpn files need to be generated and deployed to devices that use VPN. This could be sort of a "Catch 22". i.e. VPN into the Orbi to update firmware, and after the firmware update the VPN no longer works until a new ovpn file is installed, which cannot be downloaded because VPN no longer works.
