Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
Oct 22, 2019Guru - Experienced User
I can confirm with v38. Conneted Devices appears and are correctly icon'd. However after editing about three items the UI seems to stop accepting changes. Using Opera on OSX 10.14.6
Otherwise, system is working.
System Uptime 19:32:50
- grservidioOct 25, 2019Aspirant
Update went well, it took a bit to settle down and my devices connected back up. The only issue I have is not being able to update the device names via the UI or the Orbi app. The first few I made worked, but then they stopped updating.
- FURRYe38Oct 26, 2019Guru - Experienced User
NG is aware of the naming of devices issue. There working on it.
grservidio wrote:Update went well, it took a bit to settle down and my devices connected back up. The only issue I have is not being able to update the device names via the UI or the Orbi app. The first few I made worked, but then they stopped updating.
- sgraybanOct 26, 2019Apprentice
The backhaul is broken.... refuses to connect.
