Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
BIG9MM
Oct 22, 2019Apprentice
Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
Hell yes, an update to fix it!!! I would update!!
"Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest."
Oct 23, 2019Guru - Experienced User
Thank for letting us know your experiences. Be sure to do a backup configuration to file for safe keeping.
BIG9MM wrote:Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
