Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
Chuck_M
Oct 25, 2019Mentor
I was glad to see this update came in and updated flawlessly.
I do like the new icons for attached devices.
Being a Sonos owner, any tweaks are greatly appreciated.
So far, so good. No hiccups.
- FURRYe38Oct 25, 2019Guru - Experienced User
Glad it working well. Thanks for letting us know. Mines been online since the FW came out and installed. I did the manual update and reset process. The naming of the devices is a known issue which NG is aware of. Other than this. Been running solid.
Chuck_M wrote:I was glad to see this update came in and updated flawlessly.
- jasonrdunnOct 25, 2019Star
I did this update and it removed my split WiFi network, so it knocked a bunch of devices off my network and when I did the split again (to get distinct SSIDs for 2.4Ghz and 5.2Ghz) after a reboot it reverted. I am in WiFi hell. I'm going to try the split again in a bit.
And before anyone asks, the reason I had to do the split WiFi was for some home automation switches. No other way to get them set up.
- BIG9MMOct 25, 2019ApprenticeI’ve ran into issues in the past where I don’t see why you would have to split as what I had to do was turn off my 5 GHz until my 2.4 cameras connected and then once it was configured I turned on the 5 GHz and everything worked fine. So another words I didn’t have to split it I just had to turn off the 5 GHz once connected to the 2.4 everything is fine
