Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
Oct 22, 2019Guru - Experienced User
I can confirm with v38. Conneted Devices appears and are correctly icon'd. However after editing about three items the UI seems to stop accepting changes. Using Opera on OSX 10.14.6
Otherwise, system is working.
System Uptime 19:32:50
grservidio
Oct 25, 2019Aspirant
Update went well, it took a bit to settle down and my devices connected back up. The only issue I have is not being able to update the device names via the UI or the Orbi app. The first few I made worked, but then they stopped updating.
- FURRYe38Oct 26, 2019Guru - Experienced User
NG is aware of the naming of devices issue. There working on it.
grservidio wrote:Update went well, it took a bit to settle down and my devices connected back up. The only issue I have is not being able to update the device names via the UI or the Orbi app. The first few I made worked, but then they stopped updating.
- sgraybanOct 26, 2019Apprentice
The backhaul is broken.... refuses to connect.
Wired or wireless? Mines currently wired though I did test my RBS which is in the basement here and it connected wirelessly to my RBR two stories up. Seems to take about 4-5 minutes to complete the task after hitting the sync button on the RBR in the UI then button on the RBS.
Has a factory reset and setup from scratch been performed since last FW update on both RBR and RBS?
sgrayban wrote:The backhaul is broken.... refuses to connect.
