Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
sgrayban
Oct 25, 2019Apprentice
FW is JUNK.... DO NOT UPGRADE if you have separate SSID names. It will override it.
Of all the BASIC settings separate names for each SSID is often required. This FW defeats that purpose. I have IoT 2.4 ONLY devices that refuse to connect and stay connected to a common named SSID.
Get your act together Netgear... this is lame.
