Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
grservidio
Oct 25, 2019Aspirant
Update went well, it took a bit to settle down and my devices connected back up. The only issue I have is not being able to update the device names via the UI or the Orbi app. The first few I made worked, but then they stopped updating.
Oct 26, 2019Guru - Experienced User
NG is aware of the naming of devices issue. There working on it.
grservidio wrote:Update went well, it took a bit to settle down and my devices connected back up. The only issue I have is not being able to update the device names via the UI or the Orbi app. The first few I made worked, but then they stopped updating.
- sgraybanOct 26, 2019Apprentice
The backhaul is broken.... refuses to connect.
- FURRYe38Oct 26, 2019Guru - Experienced User
Wired or wireless? Mines currently wired though I did test my RBS which is in the basement here and it connected wirelessly to my RBR two stories up. Seems to take about 4-5 minutes to complete the task after hitting the sync button on the RBR in the UI then button on the RBS.
Has a factory reset and setup from scratch been performed since last FW update on both RBR and RBS?
sgrayban wrote:The backhaul is broken.... refuses to connect.
Wireless backhaul is broken.
FURRYe38 wrote:Wired or wireless? Mines currently wired though I did test my RBS which is in the basement here and it connected wirelessly to my RBR two stories up. Seems to take about 4-5 minutes to complete the task after hitting the sync button on the RBR in the UI then button on the RBS.
