Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
Oct 26, 2019Guru - Experienced User
And you did factory reset both RBR and RBS?
sgrayban
Oct 26, 2019Apprentice
Yes
- FURRYe38Oct 26, 2019Guru - Experienced User
Ok. Well, you can downgrade the system back to prior working FW version. Let us know if this fixed the wireless backhaul problem on your RBS.
- sgraybanOct 26, 2019Apprentice
Downgraade and all is good again.... I thiink I did see that someone else was having the same problem with the backhaul with the new version.
- RJSinMOOct 26, 2019Guide
So you found the downloads for both routers? Sorry, wasn't on the computer all day.
