Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
mhalla
Oct 26, 2019Aspirant
Still need to try factory reset but my RBR50 is no longer able to obtain an IP address via DHCP from my ISP. It will however obtain an IP address if I insert my old Belkin wifi/router between the RBR50 and the cable from my ISP's hardware. What did Netgear do that my ISP will no longer assign it an IP address. My ISP told me other people are having the problem as well and I need to contact Nextgear support.
Hoping the factory reset solves the problem but why should that be necessary with a firmware update?
mhalla
mhalla wrote:Still need to try factory reset but my RBR50 is no longer able to obtain an IP address via DHCP from my ISP. It will however obtain an IP address if I insert my old Belkin wifi/router between the RBR50 and the cable from my ISP's hardware. What did Netgear do that my ISP will no longer assign it an IP address. My ISP told me other people are having the problem as well and I need to contact Nextgear support.
Factory reset appears to have resolved the problem. Orbi router is now obtaining an IP address and providing an Internet connection. Wasn't sure what all a factory reset would do so was reluctant to just try it.
