Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
Oct 31, 2019Guru - Experienced User
You need to factory reset the RBR and setup from scratch. This should resolve issues seen with access controls.
Schmak01 wrote:A far warning, if you use the Access control DO NOT UPDATE as this completely messes up the device names configured. Nothing matches anymore. The names are all out of wack, got these new DEV-0x: MC:AD devices that were named. MACa addresses are right, names and IP's are wrong. So unless you want to look at all your MAC's before you disable then don't update.
Retired_Member
Oct 31, 2019A factory reset is necessary when you cannot recover your password....Still looking for FW issues...???
