Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
Oct 31, 2019Guru - Experienced User
You need to factory reset the RBR and setup from scratch. This should resolve issues seen with access controls.
Schmak01 wrote:A far warning, if you use the Access control DO NOT UPDATE as this completely messes up the device names configured. Nothing matches anymore. The names are all out of wack, got these new DEV-0x: MC:AD devices that were named. MACa addresses are right, names and IP's are wrong. So unless you want to look at all your MAC's before you disable then don't update.
Schmak01
Oct 31, 2019Apprentice
It did not. It reset everything sure, but when I go to rename my incorrectly named Echo Dots (which are all listed as fire TV...) it shows it saved and when it goes back to the screen, nope, still listed as FireTV.
- FURRYe38Oct 31, 2019Guru - Experienced User
The naming of devices is a known problem and NG is aware of it.
Hopefully will be fixed on next update. Users will need to be patient please.
Schmak01 wrote:It did not. It reset everything sure, but when I go to rename my incorrectly named Echo Dots (which are all listed as fire TV...) it shows it saved and when it goes back to the screen, nope, still listed as FireTV.
- Schmak01Nov 07, 2019Apprentice
Just an FYI I downgraded manually to 2.5.0.30 and it worked flawlessly, the attached devices is working agian, so far no issues and it runs a bit faster.
- Retired_MemberNov 07, 2019
Schmak01 wrote:Just an FYI I downgraded manually to 2.5.0.30 and it worked flawlessly, the attached devices is working agian, so far no issues and it runs a bit faster.
Nice...all of that and no factory reset.
Tip: STOP performing manual firmware updates.
