Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
Retired_Member
Nov 08, 2019
BIG9MM wrote:
This firmware update is really buggy. I have not re-installed any old Firmware as I am still dealing with the garbage Firmware that’s installed now. :(
Why did you upgrade?
BIG9MM
Nov 08, 2019Apprentice
Two reasons why I upgraded. A lot of times it’s good upgrade for security reasons and the second reason I upgraded was because it was supposed to prevent guest from utilizing the main network so another words if devices could see each other on the network guest network could actually stream stuff to my Chromecast.
- Schmak01Nov 08, 2019Apprentice
BIG9MM wrote:
Two reasons why I upgraded. A lot of times it’s good upgrade for security reasons and the second reason I upgraded was because it was supposed to prevent guest from utilizing the main network so another words if devices could see each other on the network guest network could actually stream stuff to my Chromecast.I work from home, in HCIT, so keeping my devices up to date with security patches is paramount. One thing I don't like when companies try to make things too "user friendly" i.e. dumb it down, is they omit specific security patches and updates from the update list as to not trigger folks with questions. The Orbi line is notorious for this as it's meant to be for non-technical users. So I'm right there with you on that one.
