Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
pablohoney
Nov 21, 2019Luminary
By way of an update - an email from Netgear support - addmittal of bugs in the firmware:
"I just received an update following the logs investigation.
Engineering already found some critical problems in the firmware 2.5.0.38 for both the devices list and also for WiFi stability.
Our development teams are working on releasing a fix as well as run tests on the new firmware.
The actual release plan would aim for early December for the release of said firmware."
gr8sho
Nov 21, 2019Virtuoso
đ
