wifiblues
Aug 31, 2020Luminary
new firmware
hi - I just recently updated the router to the latest firmware v2.5.1.22. the satellites are still on V2.5.1.16. do they need to be updated to the latest firmware? if so, how? thanks,...
CrimpOn
Aug 31, 2020Guru - Experienced User
wifiblues wrote:hi - I just recently updated the router to the latest firmware v2.5.1.22.
In general, the recommendation is for all components to be on the same release of firmware.
Can you identify exactly which Orbi router and satellites you have? (by model number, i.e. RBR??, RBS??)
wifiblues
the router is RBR 40 and the satellites are RBS 20 -
I actually found the update section any my current firmware is the latest.
thank you,
wifiblues
