Lariff
Jan 26, 2021Follower
New Fw for RBK50 and RBK50 v2
I search in web UI both RBK50 and RBK50 v2 and checking new FW, but no new one avaliable. Enter Netgear support pages and find for
RBK50 the new version 2.7.2.102
RBK50 v2 I find for non U.S the 2.6.1.40
It´s really unclear why not the units can find automatically the new FW and why not the same version even if the v2 is a later newer version.
Now I´m running on what the support pages recommends and updated manually.
I do have same inconsistence with also RBK20 and LBR20 where it´s not very clear what´s the latest FW and why it doesn´t find the latest FW via the App or web UI?
- vajimMaster
enter your product number, i.e. RBK50 in the download area (top of this page)
Only due to that some newer versions are not posted up on NG auto update servers that they don't appear.
You can manually download and manually install FW if you want up update:
If you do, update the RBS first, then RBR lastly.
Lariff wrote:I search in web UI both RBK50 and RBK50 v2 and checking new FW, but no new one avaliable. Enter Netgear support pages and find for
- vajimMaster
FURRYe38 wrote:Only due to that some newer versions are not posted up on NG auto update servers that they don't appear.
enter your product number, i.e. RBK50 in the download area (top of this page).......manual updates are NOT recommended
