midnightbui's avatar
midnightbui
New Home with data jacks around the house. Wondering if I can direct connect a Satellite.....
Hi, first time posting.  I think i have a dumb question.  So i just purchased a new home and it is prewired with a couple of data jacks one upstairs and one downstairs.  I have the Costco RBK53 3 pack.  So my question is this, I am aware I have to connect the Router to the modem and then can set the other two satellites around the home for coverage.  Can I actually direct connect the satellite to the network jacks to make the signal stronger or would that even matter?  I hope i am making sense.
While I am here maybe someone can help,  So I have this set up currently in my house, being that it is only one SSID name instead of having seperate for 2.4 and 5.0, my sons computer for some reason only connects to the 2.4ghz which makes it slower.  Previously when i had two SSID one for each, I am able to connect to the 5.0 and it worked fine.  I know this because when opening his connection, it is connected to the Orbi SSID but then shows it is on the 2.4gz not the 5.
Thank you in advance for those who are answering.
    • midnightbui's avatar
      midnightbui
      Thank you for the fast response.  So by doing so, it will make the signal stronger and more stable?
      • plemans's avatar
        It'll make your backhaul more stable in my experience. Wifi is great but many different things interfere with it. If there's the potential for wired backhaul, it usually works better. Especially if the wiring is already there.
  • Retired_Member's avatar
    Retired_Member
    midnightbui wrote:
     So my question is this, I am aware I have to connect the Router to the modem and then can set the other two satellites around the home for coverage.  Can I actually direct connect the satellite to the network jacks....??
    Are we all talking about the same thing?  The OP describes 'network jacks' and how they are scattered around the house.  To me it sounded like the question is "can I hook a Orbi satillite to one of the wall 'network jacks'?
