RandallTG
Mar 06, 2021Tutor
New House - Orbi Options
I am currently having a new house built. The builder installs a 30" network cabinet with a homerun to the exterior of the home for ISP service. They aslo provide Cat 6 to 2 ceiling loctions for PoE...
Mar 06, 2021Guru - Experienced User
ISP modem to swtich then to Orbi or you can go from ISP modem and have both RBR and Switch connected to the modem in parallel.
IF you want to connect the RBS wired, then you can follow this:
RandallTG
Mar 06, 2021Tutor
Is there any advantages or disadvantages to either set up you mentioned. I will have enough ports on the switch to backhaul the RBS too.
- FURRYe38Mar 06, 2021Guru - Experienced User
if you wire connect the RBS, then you'll need a switch after the RBR or directly connect the RBS to the BACK of the RBR. The connection configuration for the RBS needs to be at the RBR, not in front or at the modem or switch in front of the RBR.
- RandallTGMar 06, 2021Tutor
FURRYe38 wrote:if you wire connect the RBS, then you'll need a switch after the RBR or directly connect the RBS to the BACK of the RBR. The connection configuration for the RBS needs to be at the RBR, not in front or at the modem or switch in front of the RBR.
So if I am reading this correctly I would do the following:
ICP Router/Modem to RBR
RBR back to switch
RBS to switch
I would still be able to use the Obris as APs and the ISP modem/router as my router for the network
RBR back to switch <Where is this switch? Connected between modem and RBR? IF so, then:
RBS to RBR or RBS to another switch thats in between the RBR and RBS.
I would still be able to use the Obris as APs and the ISP modem/router as my router for the network. Yes.
