RandallTG
Mar 07, 2021Tutor
New House - Orbi Options
I am currently having a new house built. The builder installs a 30" network cabinet with a homerun to the exterior of the home for ISP service. They aslo provide Cat 6 to 2 ceiling loctions for PoE...
Mar 07, 2021Guru - Experienced User
ICP Router/Modem to RBR
RBR back to switch <Where is this switch? Connected between modem and RBR? IF so, then:
RBS to RBR or RBS to another switch thats in between the RBR and RBS.
I would still be able to use the Obris as APs and the ISP modem/router as my router for the network. Yes.
RandallTG
Mar 07, 2021Tutor
The switch will be in the telecom cabinet. I will have the orbi centrally located in the house. At that location I plan to have to Ethernet runs back to the same cabinet. So the switch would be after the RBR. it would be modem to RBR and then out of RBR to 8 port switch
- FURRYe38Mar 07, 2021Guru - Experienced User
Ok, that should work then.
What is the brand and model of this switch?
