Dirk664's avatar
Dirk664
Follower
May 01, 2020
New Install Speed
I have installed the Orbi (Model RBR10), but the wireless speed on my computer (when I am right next to the main box or a satellite box) is 20-80mb.
I connected a LAN cable to the main Orbi and connect directly to my computer and still only getting 20-80mb.
Does anyone have any suggestions on what may be the issue?
  • FURRYe38's avatar
    Please post about this over in the Orbi AC forum:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    Good Luck.
  • FURRYe38's avatar
    What is the mfr and model# of the LAN adapter in the PC?
    Besure the PC is connecting at 1000Mbps to the RBR.
