uSlackr
Jul 14, 2019Aspirant
New Install will stay connected for mgmt
Installed RBK40 this afternoon. I have a lot to learn. But wi-fi is working fine! Problem is I can no longer manage device and base is magenta. Web app says I'm not connected to Orbi wifi - but...
Jul 15, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Management page should be at 192.168.1.1 or orbilogin.com in a web browser.
uSlackr wrote:Installed RBK40 this afternoon. I have a lot to learn. But wi-fi is working fine!
Web app says I'm not connected to Orbi wifi - but I am.
I have the base in AP mode. Satellite is in wireless backhaul (want ethernet soon).
Firmware updated to latest during install. I cannot currently manage to see ver.
iOS or genie apps don't work either.
Am I doing something wrong?
\\uSlackr
uSlackr
Jul 15, 2019Aspirant
Turns out the router kept the 10.0.0.1 address it setup on the mgmt interface even after I switched to AP mode.
I switched my laptop IP to 10.0.0.2 and was able to login with https://10.0.0.1 to reset the config.
I still cannot use the orbilogin link, but I can manage it
- FURRYe38Jul 16, 2019Guru - Experienced User
You can configure a static IP address if needed on the RBR while in AP mode.
orbilogin should work. Works for me.
