uSlackr
Jul 14, 2019Aspirant
New Install will stay connected for mgmt
Installed RBK40 this afternoon. I have a lot to learn. But wi-fi is working fine! Problem is I can no longer manage device and base is magenta. Web app says I'm not connected to Orbi wifi - but...
uSlackr
Jul 15, 2019Aspirant
Turns out the router kept the 10.0.0.1 address it setup on the mgmt interface even after I switched to AP mode.
I switched my laptop IP to 10.0.0.2 and was able to login with https://10.0.0.1 to reset the config.
I still cannot use the orbilogin link, but I can manage it
Jul 16, 2019Guru - Experienced User
You can configure a static IP address if needed on the RBR while in AP mode.
orbilogin should work. Works for me.
