frodak99
Apr 16, 2019Follower
New internet provider and modem and Orbi won't connect
I had ATT as my internet provider, but when we moved they didn't provide service at my new address. I got a new modem from Spectrum and their router. I'd like to use my Orbi, but when I hook it up ...
Apr 16, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition and possible IP address conflict which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure to power OFF both Orbi and ISP Modem for 30 seconds. Then power ON the modem and let it sync, then power ON the Orbi.
