k3n85
Apr 30, 2020Tutor
New MS Edge browser unable to log into Orbi web interface
Typically I log into my router via Chrome, but recently installed the new MS Edge browser and now when I hit my router in Edge I don't get the prompt for user name password. We already know Netgear/O...
Apr 30, 2020Guru - Experienced User
Be sure the popup window is not appearing behind the main Edge window. I've see it were i've entered into the routers web page and not see the popup appear in front of the main window. However if you look at the bottom icon bar, you'll see two highlighted icons being displayed, one points to the main window, the other maybe the actual log in pop up. Not sure if this is a FW issue or a browser issue not displaying the pop up in front instead of in the background. I saw this using IE11. Possible same with Edge.
