k3n85
Apr 30, 2020Tutor
New MS Edge browser unable to log into Orbi web interface
Typically I log into my router via Chrome, but recently installed the new MS Edge browser and now when I hit my router in Edge I don't get the prompt for user name password. We already know Netgear/O...
xXRT5
Jun 20, 2020Aspirant
What link are you using? If orbilogin.com isn't working out, try using 192.168.1.1 , but if that doesn't work, connect to the local network, go on Orbi app, tap the Home (Top left corner) button, then settings. Tap "Router Settings", tap "Internet Port", then look for the "External IP Address". Take the address and put it into the computer that can't log in. If it doesn't work, look for the "Gateway IP Address", which is part of the "External IP Address". When you try to login, make sure it is followed by "/start.htm". This following slash is where you login, as the base address is simply a redirect to "/start.htm". The defaults are below, along with their extensions.
Base: orbilogin.com
Extension: orbilogin.com/start.htm
IP Base: 192.168.1.1 or 192.168.0.1
IP Extension: 192.168.1.1/start.htm or 192.168.0.1/start.htm
Just a note, I don't work for NETGEAR and am not affiliated with the brand in any way.
