avatar123
Feb 23, 2017Tutor
New Netgear Genie App
I am really impressed with the new Genie App. It looks and feels modern and is more functional now. I am now able to control my Orbi router with this app very well. It can still get better but so far...
dbnaples
Feb 25, 2017Initiate
The NetGear Genie Android app was just ruined. The Traffic meter no longer shows the actual usage! it provides only a bar graph. The actual usage in MB is gone. Can't monitor against ISP without it. Horrible design change! Are there third party apps which work?
- schumakuMar 22, 2017Guru - Experienced User
dbnaples wrote:The NetGear Genie Android app was just ruined. The Traffic meter no longer shows the actual usage! it provides only a bar graph. The actual usage in MB is gone. Can't monitor against ISP without it.
Touch the bar graphs and you will get the numbers.
