masonworld
Dec 20, 2017Apprentice
New Orbi -- Connection Issues and Drops (tales of woe)
Hey there; I just installed an Orbi system with 2 sats last month. I'm connected to a ATT UVerse router in passthrough mode. My users (my wife and kids) are complaing about unrelialble con...
southflguy
Dec 20, 2017Star
I'm having the exact same issues you are (and also have the same u-verse setup). The Orbi is dropping all wireless connections randomly. Randomly rebooting. At first I thought it was AT&T fiber service, but it isn't. The service stays connected the entire time while the Orbi drops. I'm not sure what's going on. I've had the Orbi for over a year now and when I first got it, it had similar issues but subsequent firmware updates fixed it.
- masonworldDec 20, 2017Apprentice
That's helpfup -- thanks.
As it happens, I am considering ditching UVerse due to bandwith caps and other issues (like the fact that I suspect they are partially to blame for my Orbi problems).
The cable guy (yuck) is coming out Friday to install a cable modem. I will have both running at once -- so I will be able to switch back and forth between UVerse and cable to do some testing.
If I stil have problems with the cable modem then I will know that the Orbi is the probem and will consider moving to the Linksys.
