Jul 06, 2020Guru - Experienced User
New Orbi 50 series Firmware Version 2.5.1.32 FW Release
RBR50, RBS50, RBK50, and RBK53 New Features and Enhancements: Improves the NTP sync speed and success rate Includes updates to the Terms and Conditions and adds a Privacy Policy link Bug Fix...
aptninja
Jul 10, 2020Guide
This is strange. So my router and 2 satellites have firmware version 2.5.1.16. And after clicking Check in the interface the status for each is "No new firmware version available." even though version 2.5.1.32 is available.
Is there an intentional delay between a new firmware version release and having it downloaded and available through the UI in the Online Update tab? Maybe it is intentional to ensure that if problems are discovered from customers who manually update the firmware, fixes can be made before the majority of customers who do Online Updates update their firmware? Is that accurate to assume?
Jul 10, 2020Guru - Experienced User
Seems to be a mixed bag. Some are seeing it appear in the UI and some are not. ALso may not be up on there notification servers yet either. Also this is a minor update which NG has said they don't push automatically. Minor versions are not pushed.
So you have the choice of updating or not.
