Jul 06, 2020Guru - Experienced User
New Orbi 50 series Firmware Version 2.5.1.32 FW Release
RBR50, RBS50, RBK50, and RBK53 New Features and Enhancements: Improves the NTP sync speed and success rate Includes updates to the Terms and Conditions and adds a Privacy Policy link Bug Fix...
jijun1964
Jul 14, 2020Guide
Dear, I already upgrade firmware RBR50 and RBS50 from 2.5.1.16 to 2.5.1.32. After 2 week running firmware 2.5.1.32, result more stable in wifi connectivity, still experience wifi connection loss, but can be ignore at current level.
Jul 14, 2020Guru - Experienced User
jijun1964 wrote:Dear, I already upgrade firmware RBR50 and RBS50 from 2.5.1.16 to 2.5.1.32. After 2 week running firmware 2.5.1.32, result more stable in wifi connectivity, still experience wifi connection loss, but can be ignore at current level.
