Jul 06, 2020Guru - Experienced User
New Orbi 50 series Firmware Version 2.5.1.32 FW Release
RBR50, RBS50, RBK50, and RBK53 New Features and Enhancements: Improves the NTP sync speed and success rate Includes updates to the Terms and Conditions and adds a Privacy Policy link Bug Fix...
jtam72
Jul 18, 2020Tutor
You can update them manually if you'd like. Have your router and IP addresses written down for each unit and the firmware downloaded before you start.
1. Disconnect all the ethernet cables
2. Turn off your wireless adapter on you computer
3. Connect your orbi to your PC via ethernet cable
4. Type in the IP address for the unit you're updating
5. Enter admin and whatever your password is
6. When you're in the setup go to advanced-administration-firmware update
7. Go to the manual update tab
8. Select the firmware you downloaded from Netgear
9. Hit the upload tab
I updated all three of my units and so far so good.
jijun1964
Jul 18, 2020Guide
I already update my Orbi RBR50 and RBS50, can consider best update ever. Big improve in wifi connection stability.
