Jul 06, 2020Guru - Experienced User
New Orbi 50 series Firmware Version 2.5.1.32 FW Release
RBR50, RBS50, RBK50, and RBK53 New Features and Enhancements: Improves the NTP sync speed and success rate Includes updates to the Terms and Conditions and adds a Privacy Policy link Bug Fix...
Jul 21, 2020Guru - Experienced User
FYI, I got word from NG that v32 has been pullfed or the 50 series Orbi systems. NG feels that there were problems they found that needs to be resolved.
I recommend users load v16. That version worked well for me at least. if you have v32 loaded and don't experience any problems, keep it loaded. IF you are experiencing problems, revert back to v16.
clammerds
Jul 22, 2020Apprentice
FURRYe38 wrote:FYI, I got word from NG that v32 has been pullfed or the 50 series Orbi systems. NG feels that there were problems they found that needs to be resolved.
Good to know. I have to admit, I have v32 installed and for me at least, it's been rock solid. Will leave as is for now. Will be interested to know what it is that's made NG pulli it. Obviously, if it's security reasons, I'll have to reconsider keeping it.
thanks
- FURRYe38Jul 22, 2020Guru - Experienced User
IF it works for now. let it run. If you notice anything, concider reverting. I did see one problem with status not reporting correctly for a ethernet connected RBS. Other wise, it seemed to work ok for me. I've since downgraded back to v16.
thanks
