Jul 06, 2020Guru - Experienced User
New Orbi 50 series Firmware Version 2.5.1.32 FW Release
RBR50, RBS50, RBK50, and RBK53 New Features and Enhancements: Improves the NTP sync speed and success rate Includes updates to the Terms and Conditions and adds a Privacy Policy link Bug Fix...
jhoff909
Jul 29, 2020Apprentice
In my opinion, you want the router (1100c) in regular router mode, not bridge mode. Just turn off the wifi radios so they don't interfere with / compete with the orbi. Then put the orbi in AP mode. You'll need to get the IP of the orbi from the 1100c to admin it. If you hard reset it, I think you will need your PPPoE password assuming your CL connection needs login (mine does).
Zofoor
Jul 31, 2020Aspirant
Actually it seems that this release has been removed from the website and cannot be downloaded anymore
- FURRYe38Aug 01, 2020Guru - Experienced User
Yes, v32 has been removed from NGs download site. I was informed NG found problems with it thus they removed it. I recommend using v16 as it's stable. Mines working well with it.
Zofoor wrote:Actually it seems that this release has been removed from the website and cannot be downloaded anymore
