JayFox
Aug 27, 2019Aspirant
New Orbi AC 2200 Satelllite Slow
I have Xfinity 400mbps service and just purchased the Orbi mesh system to get wifi in my garage. My speed near the modem/router combo is at about 100mbps, and out in the garage using a satellite at ...
Aug 28, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Whats the building materians comprised of?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
JayFox
Aug 28, 2019Aspirant
Thanks so much for your help. I'll try your suggestions. In the meantime, my home is 1300 sq.ft. Older construction with plaster walls. We have 7 nearby neighbors with wifi.
- FURRYe38Aug 29, 2019Guru - Experienced User
Let us know how it goes.
- JayFoxSep 11, 2019Aspirant
I'm trolling the self help articles, but am not sure where to get instructions for trying all of your suggestions. This may take a while....
- FURRYe38Sep 11, 2019Guru - Experienced User
Ok, take it slow.
Please give feedback on the question presented so we can get a better idea of your situation as well.:smileywink:
