nobrainer's avatar
Apr 05, 2018
New Orbi customer and gigabit
I recently (Tuesday, it's now Thursday) purchased an Orbi RBK50 to replace my Asus RT-ac87R/U router to provide better coverage in my townhome and becasue the asus router seemed to be struggling with the WOW Gigtopia service.
I've got it all setup, and using the 2.1.3.4 firmware, have the satelite on ethernet (showing wired connection for it), but my internal wireless speeds from my 2016 MacBook Pro w/ touchID don't seem to have gotten better, if anyhting, its a bit slower than my asus router (AC2400 speed).  Further my speedtests through Orbi's GUI are about half  (435mbits) of what I get going through chome to speedtest.net (780ish mbits), and slower than what I was getting when connected to the Asus router (840ish mbits).
Is this normal?  From all the rave reviews, I guess I expected... better?
  • Its definitely a firmware issue! I had 2.0.1.7 and speeds were super fast i had 400 down 20up on twc and my wifi & wired speeds were 400-480 down and 25 up and now after getting this update i get only 200-250 down and 25 up
    • nobrainer's avatar
      nobrainer
      Tutor
      I downgraded the router/satellite to the next lower version (2.0.1.4) and reset to factory defaults.  I think internet speeds improved by my wired backhaul is fubar.  as soon as I plugged in the cable I loose internet connection and it doesn't come back (waited about 20min); I can't get to the web gui (windows says no internet service).  I rebooted the router and satellites to try and correct the issue.  As soon as I unplug the satellite everything starts to work again, so I left the cable unplugged.
      The probelm is that the place I have the remote satellite at is apparently too far away to get a reliable signal and I have tons of dead spots now on the main level and when I move the satellite closer, then I get deadspots in the upstairs level (which is where I was trying to solve for in the firs place).
      • FURRYe38's avatar
        What is the distance between the router and satellite? I would try 40-50 feet. Mines at 40 ft in a 5000sq ft home.
        Whats the Sqft if your home?
        Any network switches being used between the router and satellite?
        I don't think 2.0.1.4 has full support for ethernet backhaul if I rememeber. Needed 2.1 for it.
        Did you factory reset after updating to v2.1 or downgrading back to 2.0 then set up from scratch?
        Others have gotten ethernet back haul working on v2.1.3.4:
        https://community.netgear.com/t5/Orbi/Orbi-wired-backhaul-performance/m-p/1548397/highlight/false#M27862
  • I'm running 2.1.2.18 with wireless backhaul and here are my iperf3 speeds
    MacbookAir wirelessly connected to satellite - 480Mbps
    Zidoo X9S Android Media player connected via wire to satellite - 835Mbps
    • FURRYe38's avatar
      And what are the wired speeds connected to the router?
      Some wireless devices don't support upwards of 900Mb +- speeds. There limited by there HW and design. You'll need to check with the Mfrs of these devices to see what max supported wireless speeds they can do.
      Always test with ethernet cable connections for most accurate speed testing. If your getting near 900Mb on wired at the router, then you good there.
        nobrainer
        Tutor
        sorry, I guess I should have been clearer.
        I do the majority of my testing through speedtest.net  in chrome on a gigabit wired windows box to achieve the higher 800+ mbit results
        when I use the web gui from orbilogin.com to do the QoS speedtest that results in about 400mbit (although since downgrading it tries and errors out eventually saying it's unable to determine speed).
        when I upgraded the orbi to the 2.1.3.4 (or whatever it is) the speedtest.net results avg'd in the 740s.
