pablohoney
Apr 18, 2019Luminary
New Orbi Firmware 2.3.1.48
Hi all, I just notice a new firmware update is available. I haven’t installed it yet but will do so now.
CrimpOn
Apr 18, 2019Guru - Experienced User
Can you post a link to this new release?
ReallyAnnoyedAF
Apr 19, 2019Star
Can't cuz there aint' one. Searched the entire Internet, no release notes. Just go ahead and step on that land mine, no problem.
I know I'm old-fashioned but none of their **bleep** ever has date stamps either.
What a ridiciulous outfit.
- KingJamesKingApr 19, 2019Aspirant
Already updated RBR50 and two RBS satellites from .44. I can't find release notes but upgrade went fine and no issues last hour
- albertkarsaApr 19, 2019Aspirant
Beware, this is buggy release. I cannot ping the satellite, and i'm unable to ping any devices directly connected to the satellite. Rolling back.
I have no issues pinging my satellites or devices attached to them.....seems to be stable so far
- snikker17Apr 22, 2019Guide
When on the Firmware Update page, you should click on the link it provides under Status first, before blindly clicking "update" or "update all" under Online Update. Then you would have seen this:
Current Version: V2.3.1.44
New Version: V2.3.1.48
Release Notes:
[Bug Fix] Fixes the GUI display issue when the language is set to Japanese.Also, when doing Firmware Updates its best to do it manually, not online, and always do the satelite unit first.
So if you go to Netgear and dont see a version higher than yours available for download, dont update.
- gr8shoApr 22, 2019VirtuosoThat's all well and good if the Orbi doesn't automatically attempt to update itself which is the default behavior of the product.
I still don't understand how sw_ was able to get a switch on firmware update screen.
