pablohoney
Apr 18, 2019Luminary
New Orbi Firmware 2.3.1.48
Hi all, I just notice a new firmware update is available. I haven’t installed it yet but will do so now.
Zephyr3200
Apr 20, 2019Aspirant
Hi
do i have to to a factory reset on v.48 even if I have done it when I installed the v.44?
thanks
tgltgl
Apr 20, 2019Star
I wouldn't if everything is working correctly and you are seeing your normal speeds and stability after the upgrade (not only for this firmware upgrade but in general I would never do it when going between minor releases which the release number indicates this one is).
