zamoose
Aug 31, 2020Aspirant
"New" Orbi from Amazon gets 404 errors on setup
Bought an RBR50 base + satellite off of Amazon Warehouse. Ostensibly only the packaging was damaged. The satellite appears to be functioning -- I can connect to the web interface there. However, the ...
- Aug 31, 2020
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Aug 31, 2020Guru - Experienced User
