JK10003
Jul 29, 2019Aspirant
New Orbi in an old apartment
I am looking to install a new wifi environment to give me service I can be happy with, and to support a new system of Sonos speakers.Our apartment is in building from 1960, and the walls are quite s...
- Jul 31, 2019
I hope you understand that "radio stuff" is not simple. We have many users on the forum who are quite happy with AC2200 systems. Strength of signal is not related to the bandwidth (AC2200 vs. AC3000). There are plenty of AC2200 WiFi's that are as "powerful" as AC3000 systems. In the particular case of the Orbi, the AC3000 "50" series has a couple of advantages over the AC2200 models: (1) the antennas are physically different and users have remarked (anecdotally) that they are "more powerful". (2) there are entirely separate radios and antennas for the backhaul connections. So the transmission between base unit and satellite does not interfere with the transmission to user devices.
If the user's internet connection has a maximum bandwidth of 20mb, all of this is pointless. The limiting factor is clearly the internet. Surplus bandwidth to user devices and for backhaul is like having a Ferrari to drive on city streets at 20mph. However, as the user's internet speed increases, the ability to provide more bandwidth to the clients and over the backhaul becomes more important.
You did mention concerns that service to the "speaker end" of the apartment was problematic with the current WiFi system. My (personal) guess is that the bathroom and kitchen are a significant factor. Only a HeatMap survey would reveal what is going on.
I purchased an Orbi RBK50 (one router and one satellite) because although I was doing fine upstairs at a linear distance of about 35 ft., the far corner of the downstairs living room (where my wife liked to sit with her iPad) and the downstairs front patio got dismal service. I put the satellite downstairs about 20-25 ft. from the router, and now I have great overage over the entire house, including the patios.
Yes, this is probably "overkill" for your apartment. The less costly RBK40 system would probably do great. One single RBR50 would probably do great. I have learned, however, that some people would rather "buy once and get on with life" than take a chance and have to rework it.
Sorry not to have an "answer." Please report what you decide and how it works out.
JK10003
Jul 31, 2019Aspirant
Thanks for the attention. Sorry for the delay, but I have done my best to lay out dimensions in a floor plan which I have attached here. Basically, the apartment is 66 ft by 23 for much of the used space. The connection from the access point (and the modem) to the television and to the wireless speakers, all planned for the future, currently goes through some solid walls, and I have not been able to improve signals much with extenders. As I said, any opinions are welcome.
CrimpOn
Jul 31, 2019Guru - Experienced User
Excellent drawing, thanks. The RBR50, which is the base unit in the RBK50 and RBK53 kits has the most powerful signal of any of the Orbi units. It looks to me like the entire space should be within range of an RBR50, with the only concerns being the bathroom construction and the kitchen appliances. An RBS5 somewhere on the side with the entrance could be far enough away from the base router and would provide strong converage in the room with the TV and speakers.
- CrimpOnJul 31, 2019Guru - Experienced User
I neglected to ask if you have something that can run a "HeatMap" application. I have found it very useful to import a drawing such as you made and walk around the space clicking on locations to record what the signal level is. I've attached a HeatMap that I made which explained why WiFi was so terrible in the back bedroom of a house when the WiFi access point is located in the opposite corner.
I used an app on an Android tablet. I have also used programs on a Windows laptop. (I am too cheap to pay, so I have to put up with Ads or live with a limited capability.)
- JK10003Jul 31, 2019Aspirant
Thanks so much. I finally made my own chart of the Orbi systems, so I think I can ask intelligent questions.
You are recommending an AC3000 kit with one satellite to cover the apartment. Does that mean that an AC2200 kit might not have enough power?
I was also asking about using a wall plug-in satellite. However, I now see that they only come in AC2200. It seems that they have the same specs as the AC2200 standalone satellite (RBS40). So it seems that the main issue in using them, if they are pluggedin at a location without much obstruction, is that they are AC2200, which has less power?
So, to repeat, you think AC3000 would be the minimum sysrem that would work well, and you think a second satellite would not be necessary?
Thanks VERY much.
JK
- JK10003Aug 01, 2019Aspirant
Again, thank you SO much, CrimpOn. Though you mght not consider that an answer, it’s much better information than I have gotten from Netgear. They are not clear in explaining and comparing features. And I think you are exactly correct that the kitchen-bathroom cluster is what has been a problem in the apartment. I have been through several routers and several extenders through the years, and I am inclined to go for a system which would be definitive. It mght be a little while yet, but I will let you know. Thanks again.
John
