RedCab
Jul 08, 2020Guide
new Orbi install - frequent disconnects when using VNC
I just replaced an Asus router with Orbi RBK43 I sit at one computer with big monitors and use VNC to remote desktop share my laptop. The laptop is using a VPN connection back to my office I...
Jul 08, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M9702
RedCab wrote:I just replaced an Asus router with Orbi RBK43
I'm getting frequent disconnects (like every 10 minutes) and the VNC has to re-establish connectivity to the laptop.
This never happened with the ASUS router. Both computers are sitting within 5 feet of the Orbi router. The laptop connected by 5G and the desktop by wire.
Is there an Orbi setting that I'm missing that is causing these frequent disconnects?
Thanks!
- RedCabJul 08, 2020Guide
Firmware: up to date
ISP: Comcast
Modem: Arris TG862G
The laptop and desktop are in the same room. Laptop connected by 5G with clear line of site. Desktop is wired.
I'll try beamforming right away
I suspicious of the guest network I set up but will try things one at a time and see...
Note I said earlier that I never had any issue with my previous router.
- FURRYe38Jul 08, 2020Guru - Experienced User
What mode is your modem working in? It has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
