RedCab
Jul 08, 2020Guide
new Orbi install - frequent disconnects when using VNC
I just replaced an Asus router with Orbi RBK43 I sit at one computer with big monitors and use VNC to remote desktop share my laptop. The laptop is using a VPN connection back to my office I...
Jul 08, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M9702
RedCab wrote:I just replaced an Asus router with Orbi RBK43
I'm getting frequent disconnects (like every 10 minutes) and the VNC has to re-establish connectivity to the laptop.
This never happened with the ASUS router. Both computers are sitting within 5 feet of the Orbi router. The laptop connected by 5G and the desktop by wire.
Is there an Orbi setting that I'm missing that is causing these frequent disconnects?
Thanks!
RedCab
Jul 08, 2020Guide
Firmware: up to date
ISP: Comcast
Modem: Arris TG862G
The laptop and desktop are in the same room. Laptop connected by 5G with clear line of site. Desktop is wired.
I'll try beamforming right away
I suspicious of the guest network I set up but will try things one at a time and see...
Note I said earlier that I never had any issue with my previous router.
- FURRYe38Jul 08, 2020Guru - Experienced User
What mode is your modem working in? It has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
