RedCab
Jul 08, 2020Guide
new Orbi install - frequent disconnects when using VNC
I just replaced an Asus router with Orbi RBK43 I sit at one computer with big monitors and use VNC to remote desktop share my laptop. The laptop is using a VPN connection back to my office I...
RedCab
Jul 08, 2020Guide
Firmware: up to date
ISP: Comcast
Modem: Arris TG862G
The laptop and desktop are in the same room. Laptop connected by 5G with clear line of site. Desktop is wired.
I'll try beamforming right away
I suspicious of the guest network I set up but will try things one at a time and see...
Note I said earlier that I never had any issue with my previous router.
Jul 08, 2020Guru - Experienced User
What mode is your modem working in? It has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
