Barbwireless's avatar
Barbwireless
Follower
Jun 10, 2020
New Orbi not connect to WiFi on pc
After set up, Apple products worked OK. PCs cant connect. When I put the password in the reply comes back can't connect to this network.
Kindle says authentication problem.
Help, please.
1 Reply
  • FURRYe38's avatar
    Did you set up a custome SSID name and PW?
    Be sure you forget any prior wifi profiles in the PCs network settings.
    Be sure your using WPA2 and AES wifi security settings on the RBR. Use as web browser to check the RBRs web page.
