tomtendo
Mar 01, 2019Aspirant
New Orbi RBK50, but Upload Speeds are slower than before?
I just installed our new orbi rbk50 and while download speeds are fine... my upload speeds are half what they use to be on my airport extreme... what gives????? Do I really have to return this?
Mar 01, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Are these speed results wired or wireless?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
tomtendo
Firmware is the latest one. I checked for new several times. V2.2.1.210
My modem is a Surfboard SB6183, Arris.
No idea if in router or AP mode. How can I tell? I never was asked this.
House is 3400sf. Signal isn't an issue right now. Upload speed is.
I would say the Satelittle is about 30 feet away, upstairs (Modem is downstairs).
WPA is "WPA2-PSK [AES]"
Not sure what you mean or where for "
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)."
- tomtendoMar 01, 2019Aspirant
It's in Router mode.
- FURRYe38Mar 01, 2019Guru - Experienced User
Router or AP mode can be found under Advanced Tab/Advanced Settings/Router or AP mode menu. Yours is probably router mode as it's default out of the box.
Look under Advanced Tab/Advanced Settings/Wireless settings for those advanced features.
Be sure to test wired LAN cable speeds with a PC or latop first, then test wireless.
My pc which is wired to the router jsut got 295/22 which is probably what it was before. Wifi tho... and literally 2 feet away from same router is 290s/12
Ok so wired speeds are good.
What device are you using to test wireless?
Try all available wireless devices to check speeds.
Ensure Beamforming is also enabled.
