tomtendo
Mar 01, 2019Aspirant
New Orbi RBK50, but Upload Speeds are slower than before?
I just installed our new orbi rbk50 and while download speeds are fine... my upload speeds are half what they use to be on my airport extreme... what gives????? Do I really have to return this?
tomtendo
Firmware is the latest one. I checked for new several times. V2.2.1.210
My modem is a Surfboard SB6183, Arris.
No idea if in router or AP mode. How can I tell? I never was asked this.
House is 3400sf. Signal isn't an issue right now. Upload speed is.
I would say the Satelittle is about 30 feet away, upstairs (Modem is downstairs).
WPA is "WPA2-PSK [AES]"
Not sure what you mean or where for "
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)."
tomtendo
It's in Router mode.
