tomtendo
Mar 01, 2019Aspirant
New Orbi RBK50, but Upload Speeds are slower than before?
I just installed our new orbi rbk50 and while download speeds are fine... my upload speeds are half what they use to be on my airport extreme... what gives????? Do I really have to return this?
Mar 01, 2019Guru - Experienced User
Ok so wired speeds are good.
What device are you using to test wireless?
Try all available wireless devices to check speeds.
Ensure Beamforming is also enabled.
Chrisddo
Mar 02, 2019Aspirant
I’m having exactly the same issues. Max wifi upload speeds have been neutered to half compared to other mesh systems I have tried in my home. I’m very close to doing a return and going for a Deco M9 setup.
