tomtendo
Mar 01, 2019Aspirant
New Orbi RBK50, but Upload Speeds are slower than before?
I just installed our new orbi rbk50 and while download speeds are fine... my upload speeds are half what they use to be on my airport extreme... what gives????? Do I really have to return this?
tomtendo
Mar 02, 2019Aspirant
I was good for a couple hours via wired and wifi. getting 17+ upload. Now I am getting sub 10s both wired and wifi. I've tested on Macbook pro (2018) and iPads and iPhones.
I turned on Implicit BEAMFORMING and now wifi is even slower... 92 and 7 up.
tomtendo
I just got 292 and 2 upload. This upload is a joke. What’s the deal? How can my 6 year old Apple airport do better than this?
- FURRYe38Mar 02, 2019Guru - Experienced User
I would try to upgrade the FW, upgrade the satellite(s) first then the RBR router. You'll need two files for the RBR, v212 and v32:
Upgrade via lan cable. I would factory reset and setup from scratch after v32 is applied with the RBR.
