Tgterm
Aug 14, 2017Guide
New Orbi RBK53 install - a few drops, questions about MU MIMO and Beamforming
Hi - installed Orbi router and two satellites a few days ago. Firmware v1.12.0.8. Window 10. Have had a few brief drops on one of the satellites using an iPad. Also noticed that MU MIMO and Beamf...
Tgterm
Aug 15, 2017Guide
Hi -
I know this is being discussed in a variety of threads, but I was just hoping for a straight answer from someone in the know...I have seen some Netgear reps comment here and there in these threads.
Should I enable Beamforming? Should I enable MU MIMO?
Will that increase or decrease the number of drops I have been experiencing, or increase it? What is the latest position on this?
Is there a firmware release I should be waiting for before I do these things instead?
I have even PM'd DarrenM...no response.
Sigh...
Thank you.
- DarrenMAug 17, 2017Sr. NETGEAR Moderator
Yes with the latest firmware those features should help what your seeing about having them off was a old issue.
DarrenM
- TgtermAug 17, 2017Guide
Thanks, Darren. I did enable those features a couple of days ago. I am still seeing some occasional drops where my iPad indicates that it cannot find the network, then after a moment or so it comes back up. Usually on my iPad, when using it in the vicinity of the satellite furthest from the router. This satellite glowed blue when I set it up, so I am assuming distance from the router is not an issue.
Based on what I have been reading in these forums, this seems to be a known issue under some varying circumstances. Is there work in progress to release a firmware version that will prevent these drops in the near future, or is there something else I should be doing on my end? Thanks.
DarrenM wrote:Yes with the latest firmware those features should help what your seeing about having them off was a old issue.
DarrenM
Hello Tgterm
Yes the engineers are always looking at the community and the cases from support to try and fix any issues that are happening. The other things you can try is adjusting the wireless channel and maybe trying to re position the satellites and see if anything changes.
DarrenM
- Arjun0oAug 23, 2017Guide
First you have to understand what implicit beamforming and MU-MIMO do.
Implicit beamforming is a feature which allows the router to broadcast WiFi signals in a specific direction. It boosts the WiFI signals. If you are experiencing a drop in the connection, this feature should be enabled.
MU-MIMO most of the devices today do not support it, yet. It basically divides the bandwidth so that all your devices receive good signals. I think it only supports upto 4 devices at the moment. This feature does not make much difference. I would not enable it.
If you are experiencing wireless intermittent issues, these are some things you can do on your end.
1. Change the WiFi channels for 2.4Ghz and 5Ghz. Choose the non overlapping channels like 1,6,11.
2. Check the firmware version on the router and the satellites just to make sure it is the latest.
3. Make sure you do not have electronic devices near the router or satellites especially wireless speakers or cameras. They interfere with the WiFi signals.
I hope this helps.
- JeffParkerAug 25, 2017Tutor
Arjun0o wrote:First you have to understand what implicit beamforming and MU-MIMO do.
I hope this helps.
OK thanks! I will try that (as well as keep MU-MIMO unchecked)
- JeffParkerOct 19, 2017Tutor
I enabled BF and immediatly started having issues with 1 of the satellites - it would just lose connection on/off!! Router is in master closet about 70ft away from satellite.
I turned it back off and now the satellite stays connected but it's back to the same old issue - dropping intermittently!
Sigh - so fed up of this product. Looking at returning and buying the Linksys
- st_shawOct 20, 2017Master
To avoid issues you need to do both of the following:
1. Turn off the WiFi radios on your modem.
2. Either set the modem into bridge mode to disable it's routing fuctions, or run Orbi in AP mode.
Did you perform both of these steps?
