Tgterm
Aug 14, 2017Guide
New Orbi RBK53 install - a few drops, questions about MU MIMO and Beamforming
Hi - installed Orbi router and two satellites a few days ago. Firmware v1.12.0.8. Window 10. Have had a few brief drops on one of the satellites using an iPad. Also noticed that MU MIMO and Beamf...
DarrenM
Aug 17, 2017Sr. NETGEAR Moderator
Yes with the latest firmware those features should help what your seeing about having them off was a old issue.
DarrenM
Tgterm
Aug 17, 2017Guide
Thanks, Darren. I did enable those features a couple of days ago. I am still seeing some occasional drops where my iPad indicates that it cannot find the network, then after a moment or so it comes back up. Usually on my iPad, when using it in the vicinity of the satellite furthest from the router. This satellite glowed blue when I set it up, so I am assuming distance from the router is not an issue.
Based on what I have been reading in these forums, this seems to be a known issue under some varying circumstances. Is there work in progress to release a firmware version that will prevent these drops in the near future, or is there something else I should be doing on my end? Thanks.
DarrenM wrote:Yes with the latest firmware those features should help what your seeing about having them off was a old issue.
DarrenM
- DarrenMAug 17, 2017Sr. NETGEAR Moderator
Hello Tgterm
Yes the engineers are always looking at the community and the cases from support to try and fix any issues that are happening. The other things you can try is adjusting the wireless channel and maybe trying to re position the satellites and see if anything changes.
DarrenM
- JeffParkerAug 22, 2017Tutor
DarrenM wrote:Hello Tgterm
DarrenM
Darren,
I'm a little perplexed by these continued ambiguous responses about MIMO/BeamForming. I see posts dated all the way back to last yr and as of today 8/23/2017 there still no fix or actual respose for this issue.
Does it work or not? Why is it still unchecked even after the V1.12.0.18 FW upg?
- martyfpAug 23, 2017Luminary
FWIW - i'm on 1.12.0.18 and have both enabled, my system works really well, no significant drops and everything is very stable. That said, stability was much the same before I enabled them (on same f/w).
