Tgterm
Aug 14, 2017Guide
New Orbi RBK53 install - a few drops, questions about MU MIMO and Beamforming
Hi - installed Orbi router and two satellites a few days ago. Firmware v1.12.0.8. Window 10. Have had a few brief drops on one of the satellites using an iPad. Also noticed that MU MIMO and Beamf...
Arjun0o
Aug 23, 2017Guide
First you have to understand what implicit beamforming and MU-MIMO do.
Implicit beamforming is a feature which allows the router to broadcast WiFi signals in a specific direction. It boosts the WiFI signals. If you are experiencing a drop in the connection, this feature should be enabled.
MU-MIMO most of the devices today do not support it, yet. It basically divides the bandwidth so that all your devices receive good signals. I think it only supports upto 4 devices at the moment. This feature does not make much difference. I would not enable it.
If you are experiencing wireless intermittent issues, these are some things you can do on your end.
1. Change the WiFi channels for 2.4Ghz and 5Ghz. Choose the non overlapping channels like 1,6,11.
2. Check the firmware version on the router and the satellites just to make sure it is the latest.
3. Make sure you do not have electronic devices near the router or satellites especially wireless speakers or cameras. They interfere with the WiFi signals.
I hope this helps.
JeffParker
Aug 26, 2017Tutor
Arjun0o wrote:First you have to understand what implicit beamforming and MU-MIMO do.
I hope this helps.
OK thanks! I will try that (as well as keep MU-MIMO unchecked)
